Type is defined in an assembly that is not referenced (Visual Studio with RhinoCommon) [Solved]
I have been trying to compile a visual studio project that contains a lot of Rhino Plugins lately and while I had a lot of errors at the beginning (around 400 compiler errors),
I managed to reduce almost all the errors. Mostly they were of the following type: “some external namespace” couldn’t be found. I then installed all the necessary nuget packages and visual studio extensions through the Visual Studio Gallery online (QuickGraph, Newtonsoft.Json, Eto.Forms, etc. for example) …
…and now I am down to only having one error which I can’t handle myself.
The compiler error I get is the following:
CS0012 - The type “DialogResult” is defined in an assembly that is not referenced. You must add a reference to assembly “System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089”.
It appears to me that the standard Windows.Forms Dialog namespaces are colliding with the Rhino.UI. Here is the code: The second line is underlined red.
var dlg = new Rhino.UI.OpenFileDialog { Title = "select file", DefaultExt = "json" };
dlg.ShowDialog();
I installed the RhinoCommon templates v5, I even added RhinoCommon.dll manually.
I have Rhino 5 for Windows installed as well. I am using Visual Studio 2015 with Xamarin (because we want cross platform GUI functionality).
I hope someone can help me fix this very Windows-specific issue (as it appears to be).
Ivan
Hi Ivan,
Does your project reference the System.Windows.Forms assembly?
– Dale
Dear Dale,
I’ve seen that you answer a lot of questions on this forum and I want to thank you for that.
And especially in this case, I want to thank you even more because you solved my issue!
So my guess is that the guys developing the project use Mac + Eto.Forms for ShowDialog and because they use a Mac, they don’t need to reference Windows.Forms obviously, but I need to do that and as you thought:
Yes, there was no such reference which I now added and boom, it works!
So thank you very much again Dale!
All the best,
Ivan
