Two-sided material
I want to add two materials to one poly-surface.
I have used this method:
However I am only able do assign a different material to one side. What I want to achieve is one material for the edges and another for the faces.
Think: doublesided laminated plate with a plywood core.
See this video for visual explanation of the problem
You should do sub-object selection also for the other bits and assign only to that selection the material of your choice.
The way you do it in your video is overriding the sub-object material because that face is also being selected with the drag&drop method.
Thanks for the help!
Didn’t quite understand your answer. But understood what I wanted to do was possible, but I did it wrong.
For future people googling:
  1. subselection with ctrl+shift and choosing the faces before the material.
  2. Apply materials to object (drag doesn’t work) (OBS: Apply to materials happens when right clicking the material. Lost it in frame rates in the video )
    (this worked for me)
Is there a smarter way @nathanletwory athan?
Not at the moment.
I have created a feature request for this case: https://mcneel.myjetbrains.com/youtrack/issue/RH-52529
Thanks!
Just wanted to make sure.
Thanks for creating the feature request. For me the dragging feels like a very natural applying method.
For the sake of completeness. Apparently the smarter way is:
@andy, did you really had to reject the proposal? I (and probably many others) have multiple keyboard layouts on windows. I have my own hybrid containing US layout with German umlauts placed so I can also type in German without having to remap my muscle memory. The default key for this in windows is Ctrl+Shift. I believe the request is valid and ctrl+shift is not very acceptable. There should be a way to toggle it. And to be able to directly drop material on sub-objects.
German keyboard layout is horrific. Every symbol is misplaced. Same goes for the French one.
I have tried this. I just cannot get to work if I want to have two faces with a secondary material. With this method I can only get it to apply on one face.
Yes, I confirm that ctrl+shift+drag-drop material is not working as described.
