So I’m trying to do something really straightforward and encountering a strange issue. I’m doing two shears on some grouped geometry, resulting in a cavalier projection when using a front view.
There is nothing weird about the geometry, they’re just regular closed polysurfaces. Does anyone know why this is happening? It’s very frustrating and I don’t even know how to describe the issue. I’ve tried in both Rhino 6 and 8.
When shearing, make sure you enable “Project” in object snaps, so that you only shear in one direction at a time. Best to share an example file, that shows a before and after what you are doing. Images don’t tell that much, other than that I see it’s not the result you are after.
Hi Mitchel - that seemed to work OK here - angles not correct but the process worked - I think Gijs’ comment about making sure to project Osnaps seems like it might be the thing.
