Two session open, one autosave :(
One big working file open, default autosave set to 2 minutes.
Open second Rhino instance, make a rough sketch, a rounded cube. Same default settings are in effect.
Computer crashes, no fault of Rhino.
Despite hours of work on the big file, only the autosave file of the rounded cube exists.
Last named autosave of the big working file is several hours stale.
Did you check your bin ?!
Good point, the files are in there. Thanks, built back better, as is always the case.
