I wish to run both, the square sweep in combonation with the round sweep? I can get it to do either but not both. I made the degree the same on all round and square sweeps . yet cannot blend from square to round and back to square??
attn: Kyle tech , Thank you
@sam_barnett will you attach your file please?
I get this if I try to recreate your set up-
the red curves are you rails (joined)
the blue curves are your profiles (also joined)
pick the two rails, then the profiles in order from left to right, or right to left,
do not include the black curves.
thank you Kyle . the help us mucho appreciated !
