'two point camera' issues
This happens very often:
when I have a display set to two points camera the image saved doesn’t represent what’s on the screen.
Saved image comes as regular perspective, out of focus or doesn’t come at all (white).
Two point camera is messing also with Human’s print text to screen in Grasshopper resulting the text being in any location but chosen.
Hello - how are you saving the image?
ViewCapture
Hello - so far this appears to work here - if you have a simple case where it does not, can you please post it? Ideally just a box…
I will send you later the file I am working on. Don’t get easy with a box…:sweat_smile:
File has been sent to tech.
Hello - thanks, I have the file - which viewport are you capturing? There are two viewports called View 2 and neither opens in 2 point perspective…
Here, both capture correctly if switched to 2 pt. All the named views, so far, work at 3000 x 2000 …
@Piotr - your comment in the email implies it may not always happen, even at your end, is that correct?
Views 5 to 9 are two points only.
True. There is no rule to it, nor camera settings except when it does, camera is always set to 2-points.
I was going to post a similar or the same issue. Suddenly View Capture doesn’t work properly if the view is saved with Two Point Perspective. It only captured a small corner of the screen. If I change the camera to Perspective and move around a little, then View Capture would save the whole screen.
@Piotr, did you get this issue solved?
@l11 can you provide more info? I tried to repeat this but so far it works as expected.
Just sent you a link to download the file.
I save the view as Two Point Perspective. When used View Capture to File command, the image file is saved like this.
This happens when you move around in the view, then change it to Two Point Perspective. Create Named View without moving / changing the view. The image gets mostly cropped out when view capture to file.
I don’t get any issues with it here. Tested in 8.6.24086.23001
Version 8 SR5
(8.5.24072.13001, 2024-03-12)
Yours is more recent? Rhino says mine is up to date. I just tried the same in another file, and the same thing happens.
hi @l11 I’ll try tomorrow in 8.5 to see if it is version specific. You can download a more recent version by enabling statistics and download the 8.6 Service Release Candidate
