I can’t seem to get two Rhino instances running concurrently with two different schemes.
Is there a way to achieve this ?
What happened is when another Rhino instance loaded with different scheme, it automatically attempt to close the other instance, or itself if the other is busy.
Steps to reproduce:
Start Rhino instance with default scheme (instance A)
Create another Rhino shortcut with a new scheme.
Start using the new shortcut. (instance B)
Rhino instance A will attempt to close itself, only prompts if there is unsaved changes.
Rhino instance B will attempt to close itself if instance A is busy.
Occasionally there are some delay between step 4, and step 5.
Windows 10.
Rhino Version 7 SR6
(7.6.21127.19001, 2021-05-07)
From this post Lost license I can confirm that Google Drive is not running.
Possibly something to do with Cloud Zoo licensing?
This dialog appears every time I switch scheme and the other instance closes immediately before the dialog, and after I respond.
