crazy.gh (19.9 KB)
I think I am going crazy…
I have two radial arrays of two objects that should fit perfectly and for some reason they don’t:
i work with conical surfaces and I created an radial array of cylinders that create 5 arcs around a cone. then from one of these arcs I created a conical surface (the white wall) and created another array with it. both arrays have the xy plane as center, have 5 copies but for some reason you can see an opening on the top right corner of the image. these surfaces should coincide at the edges.
I don’t know what could be wrong. is it the array component not working or the cone on the top having some kind of transformation?
I am really puzzled!
