Twisting a simple chain link
hello everyone im trying to twist this simple geometry so i have something similar to this
but the twist always turns out weird and not how it should be ,any thoughts please? thanks!
unnamed.gh (11.0 KB)
The Twist component is strange… changing the length and position of the twist axis line changes the end result considerably where as I would have thought that would make no difference.
I tried moving the initial shape so it was exactly on the origin and making the twist axis lie exactly on the origin too. If you experiment with lengthening the line and adding more twist you can see what is happening better but I don’t know how to get it to do what you want in your top image.
Probably understanding how the twist component works would help.
I wonder if some sort of mesh cage edit would work better?
TWIST.gh (13.2 KB)
hello thank for the response yeah the twist component is completly strange i tired playing around with it and still not close to what i wanted… i tried mesh cage and also could not work…
