Twisting a connector
Hi There!
One quick question: How can I twist the connector shown in the picture below while retaining its functionality?
The hole in which the rod is inserted gets deformed when I use the “twist” command.
Is there a way to keep the shape of the hole, I`d really like to do some non-orthogonal connections ;D
Thanks in advance!
I think you’ll need to model each one individually.
It might be possible to dream up a Grasshopper definition that would work if you come up with a strategy for modeling them that would work at any angle.
If you’ve got a bit of the shape between the holes that can twist, you might be able to do this with a cage edit if you use enough cage points-
Unfortunately my grasshopper-skills aren’t quite sophisticated enough to make that work I think.
Thanks anyway!
Cage edit works just fine, thanks a lot Daniel!
