gtm947
(Gtm947)
August 3, 2022, 8:02am
1
Hi everyone,
It would be great to have your inputs on this.
I want to create a facade with louvers that comprise of 6 curves lofted, ,and between the angles 0 0 90 90 180 180. These are the angles to have the 90 90 angles curves should be able to be mapped to a curve so I can be able to control their continuity on the facade. I did a small algorithm but its mostly manual editing.
I did this using pufferfish and tween through curves to get the straight effect between lofts.
The red lines are the curves I used to get this effect, but over a large facade doing it manually is very time consuming.
gtm947
(Gtm947)
August 3, 2022, 8:05am
2
These are the surfaces I need to translate this effect on. Overall strips are about 300 so its hard to do this manually.
Post your Rhino and Grasshopper files.
You appear to be using a cracked Rhino. I wonât be able to help you:
Testing 3dm Archive: C:\Users\martinsiegrist\Downloads\Flip facade.3dm
Start Section: 463 bytes (offset 0 to 463)
Offset: 0
3dm archive version: 70
Interface Name: Rhinoceros 7.17 - Corporate , build 2022-04-12 - (compiled Apr 12 2022)
SDK Version: 2348836105.2386853825
OpenNURBS Version: 2386853825
It would appear that he is, yes; there is no âCorporateâ Rhino from usâŚ
gtm947
(Gtm947)
August 3, 2022, 9:23am
6
I understand. I will comeback with a legit file. Until then, thanks.
gtm947
(Gtm947)
August 19, 2022, 9:43am
7
Rhino 7 SR1 2020-10-25 (Rhino 7, 7.1.20299.23101, Git hash:master @ 8d9ce31398d29589acec390d2167dc68806d5b79)
License type: Commercia, build 2020-10-25
License details: Stand-Alone
Windows 10.0 SR0.0 or greater (Physical RAM: 32Gb)
Non-hybrid graphics.
Primary display and OpenGL: NVIDIA GeForce GTX 1070 (NVidia) Memory: 8GB, Driver date: 6-23-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 516.59
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-23-2022
Driver Version: 31.0.15.1659
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V6\VRayForRhino.rhp âV-Ray for Rhinoâ
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp âCommandsâ 7.1.20299.23101
C:\Program Files\Rhino 7\Plug-ins\rdk.rhp âRenderer Development Kitâ
C:\Program Files\Rhino 7\Plug-ins\AnimationTools.rhp âAnimationToolsâ
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp âRhino Renderâ 7.1.20299.23101
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp âRDK_EtoUIâ 7.1.20299.23101
C:\Program Files\Rhino 7\Plug-ins\rdk_ui.rhp âRenderer Development Kit UIâ
C:\Program Files\Rhino 7\Plug-ins\NamedSnapshots.rhp âSnapshotsâ
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp âRhinoCyclesâ 7.1.20299.23101
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp âToolbarsâ 7.1.20299.23101
C:\Program Files\Rhino 7\Plug-ins\3dxrhino.rhp â3Dconnexion 3D Mouseâ
C:\Program Files\Rhino 7\Plug-ins\Displacement.rhp âDisplacementâ
Could you confirm now if I have a legit rhino?
gtm947
(Gtm947)
August 19, 2022, 10:04am
8
wim
(Wim Dekeyser)
August 19, 2022, 10:08am
9
Hi -
Gtm947:
Youâll have to update to the current versionâŚ
wim
(Wim Dekeyser)
August 19, 2022, 10:35am
12
Martin Siegrist:
Whatever that meansâŚ
that means different crackâŚ
-w
gtm947
(Gtm947)
August 22, 2022, 4:18pm
14
Rhino 7 SR21 2022-7-27 (Rhino 7, 7.21.22208.13001, Git hash:master @ c31aea87137a5d0de449338a7ef6856f49dd4797)
License type: Commercial, build 2022-07-27
License details: Cloud Zoo
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 32Gb)
- Windows Main Display is laptopâs integrated screen or built-in port
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 4.6 (primary GPUâs maximum)
Anti-alias mode: 4x
Render version: 4.6
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp âCommandsâ 7.21.22208.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp âRhino Renderâ 7.21.22208.13001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp âRDK_EtoUIâ 7.21.22208.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp âRhinoCyclesâ 7.21.22208.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp âToolbarsâ 7.21.22208.13001
C:\Program Files\Rhino 7\Plug-ins\digitize_MicroScribe.rhp âMicroScribe Digitizerâ
Guess updating does fix it.
gtm947
(Gtm947)
15
Anyone wants more proofs?
