I want to select twisted boxes located on black regions. Can you help me, please?
Thanks in advance
twisted box.3dm (268.3 KB)
twisted box.gh (41.9 KB)
Thanks in advance
I think you can see it now
twisted box.3dm (419.5 KB)
twisted box.gh (27.8 KB)
One {first} quick way, because youâve already identified the mesh faces on black regions, is to move one stack of twisted boxes to the locations (centroids) of said faces:
twisted box.gh (32.7 KB)
Thank you so much
Another {second} quick way is to find all stacked twisted boxes that âcoincideâ with the mesh face centroids:
twisted box2.gh (33.0 KB)
Cheers!
These are so beneficial for my thesis. Thank you, again
@René_Corella Hello Rene,
I want to ask you another question similar to this example. I want to apply the same method to distribute my lattices based on surface color. I tried to use the same definition on my model, but an error happened. My lattices donât touch and connect to each other. They are distributed improperly. How can I fix it? I ask for your help if possible.
Thanks in advance,
anticlastic lattice shell.gh (161.6 KB)
Hi, I donât have millipede installed - could you internalize the objects and maybe show a screenshot of what youâre after, that always helps
Sure! I believe you can see it now.
internalise anticlastic lattice shell.gh (184.2 KB)
cool, thanks - because you already had culled mesh faces from color, I thought you could rely on that mesh to intersect it with MeshRay:
internalise anticlastic lattice shell.gh (190.4 KB)
*Note:
Reuploaded the file to get rid of the group parmeter you see in the image - not needed
*Note 2:
I used Cull Pattern so stuff not on black color went away - I guess you can use Dispatch instead.
Cheers
Thank you for your reply. I have a problem with lattice cell distribution. Cells are located in the proper position but they donât accurately connect to each other. Do you have an idea how to solve it?
If I understand correctly, you wish to morph your module lines to the âvoxelsâ so the lattice can (1) follow the shape and (2) make these lines actually connect for the purpose of using Multi-Pipe?
Like the image below?
If yes, I used box morph and then deleted the duplicate lines.
Result is one closed SubD.
Check here:
rc_internalise anticlastic lattice shell (1).gh (116.4 KB)
It looks nice! Thank you so much.
Dear Mr. Rene,
I know I take up a lot of your time. Sorry for that. However, I need to ask one last question. I encountered a research paper that had a similar intent to my work. According to the paper, they have divided the surface analyzed by Millipede into 5 zones by color. As you know, we can separate my model into two zones black and white. Can we further divide the colored surface into two more zones? That is, can we separate our voxels into white, gray, dark gray, and black zones? I need your help last time.
Thanks in advance,
Hi Alim,
I think youâre now trying to cull mesh faces based on color zones, which means you can probably use Divide Domain for the matter.
Something like this:
for_mr.Rene.gh (217.7 KB)
Thank you so much, Mr. Rene. According to your definition, I think there is a small mistake. Some of the mesh zones of index 0 and 2 are overlapping each other. The gray areas are selected by both indexes. How can I select these gray areas separately?
Hey Alim, apologies - couldnât come see this earlier.
Youâre correct! I definitely misinterpreted your previous question about the mesh zones and then gave you a potato instead
(I read âzonesâ in your doodle and threw mesh faces into those buckets without considering the indices of the mesh faces).
Anyway, I think (if Iâm getting it right this time haha) you might want to rely on something more like âcolor stepsâ instead. For this youâd have to find domains more than testing for value inclusion.
Check the attached revision, thereâs a âplayfulâ way and a âstrictâ way:
for_mr.Rene.gh (256.5 KB)
Thank you very much, Mr. Rene. You helped me a lot. You are the best.
