I just tried loading Rhino 7 and am now getting this message that prevents me from doing anything. Any recommendations?
Maybe you can open Rhino in Safe Mode (plug-ins are disabled) and then permanently disable the Tweener plug-in.
Thanks, but that did not work, even though I disabled it in Safe Mode, I’m still getting the same message.
Did you install that by PackageManager?
In that case you can uninstall it through the PackageManager.
If not, you can manually remove the plugin from grasshopper.
the packages are in
%appdata%\McNeel\Rhinoceros\packages
The manually added gh plugins should be here:
%appdata%\Grasshopper\Libraries
Thank you Gijs. I didn’t see it in Package Manager, but found it under Rhino packages, and deleted every atom of its existence! Well, there’s a night completely wasted.
