TweenCurves wish: keep direction
If I select two curves to tween, the resulting curves are oriented depending on where I clicked on the curves. It would be nice if the general curve orientation could be preserved, possibly with a commandline option.
In the file, select all curves and use the Dir command to see the differences in outcome.
tweencurves.3dm (33.2 KB)
Hi Menno - thanks, I’ll see if that can be tuned up.
Hmm - actually, I cannot repeat this right now- all curves end up pointing the same way as the inputs.
