TweenCurves and Osnap
While the preview of TweenCurves is active, I can snap to points.
In order to change directions.
This is not obvious, the command line offers Flip, but no hint that one can already do that without activating Flip.
  1. In case of Count = 1 it would be handy to set the position of the generated element somewhere else than in the exact middle.
  2. The preview color is wrong.
    It’s simply black, regardles which layer is active.
    The color is also not the standard previev color like in e.g. polar array.
_loft
_extractIsocurve
not every “Mirco-Workflow” should be an option in related commands - otherwise rhino will be blown up full of those not everyday options requested by a few users.
hope above helps - kind regards - tom
True.
That’s not the same.
then i did not get it - what do you mean by “position of the generated element somewhere else” ?
_loft the grey surface - generate a endless number of tweencurves if you want see it like this
_extractIsocurve - extract the one you want
what do i miss ? what are you after ?
Try with something like that and see the different results:
What you achieve by extracting isocurves.
Which is a good solution we all know for > a quarter of a century :wink:
