I would like to ask if anyone knows how to tween between the curves on the two surfaces but with lower distances at the lowest part and greater at the highest part. Additionally if all the distances vary between them would also be the desired effect. I tried with the graph mapper but didn’t make it work.
I am attaching two images hopefully to make more clear what I mean.
This is what I was looking for. Thank you very much.
On my definition though after changing a bit the shapes, the tweening of the curves seems to be reversing between the two curves. I tried flipping the normals but still I have the same issue.
Maybe it is more evident when you use a normal slider on the tween factor and not the graph mapper.
Do you know how I could fix this?
