Tween Object command ? Or another way to achieve this?
Hi All,
I am trying to run a pattern along a 3D curve, which gradually becomes smaller.
Using Flowalong curve (on a projected curve on the geo) has provided good results for a sphere. (Which I have laid out on a line the same length and used tweensurface command on
But now I am trying to use a diamond shape, I can’t get it to work. Is there anything such as a TweenObject command ? Or another way to achieve what I am after ?
Thanks
Ian
are you looking for a workflow to just scale the objects - or to deform them ?
back / top (deforming)
front (scaling)
what exactly do you mean by “diamond shape” ?
maybe post a file ?
kind regards -tom
Hi Tom, I would like them to be individual entities that scale down in size, as per the spheres do when using the tween surface command , but this isn’t available with the pyramid shape
you can build a pyramid as a single surface:
turn off the use of Extrusions and creaseSplitting
_useExtrusions
_creaseSplitting
(Edit: reset / turn on after the workflow - like pascal mentioned below)
draw the base
_extrudeCrv
_pointsOn
_setPt (x,y to center)
now tweenSurface works
_divideAlongCrease
_join
_cap
(edit) - file:
pyramid_tweenSrf.3dm (2.9 MB)
This should do what you want, but the full version is not free:
amazing than you Tom
Don’t forget to turn CreaseSplitting back on when you are done - normal Rhino expects this to be enabled.
