Tween Curves SamplePoints Setting
I was using the Tween Curves command with the SamplePoints Match Method. I increased the sampling number to a certain amount, I think it was 10,000 or 100,000 and after that the command was unresponsive. Now, whenever I try to use Tween Curves with that matchmethod, the command just stops.
Is there a way to reset the settings on the command?
Thank you!
Thadd
Run the command without any geometry selected.
