V5
I go to vimeo McNeel 94 tutorials put mesh in search it says 0 videos found.
apart from failing to find anything about setting up V5 viewports, the last article was McNeel for v4, I cannot find anything about use of Rhino for reverse engineering apart from suggestions for buying not cheap plugins, I dont have their sort of money, same price as rhino costs, as if the native tools are simply inadequate, if only I could find some tutorials on how to use the native tools, .
For a moment I thought I had found tuts but they are all dead ends.
Where has McNeel put the tutorials for using V5 on meshes ?
I so want to get started but cant find anything.
McNeel have at this address:-
https://wiki.mcneel.com/rhino/reverseengineering
a pdf article describing mesh editing starting with the described way of creating two new viewports to enable this. Thats the magic ingredient I bet where other tutorials skip that and nothing they show works !
However its for v4
I cannot find such for v5.
Where is the McNeel article on getting started for v5 ?
I have choppy sea type meshes from agisoft, it takes several hours to do a dense point cloud then mesh and I cannot use my pc at all apart from internet posts as its totally hogged by power needs.
I need to curve and surface them, all these purchased progs are shown working on smooth meshes !
I need to orient mesh and cross section, snap to surface and redraw the lines and curves and judge how close a fit my surfaces are.
Regards
Steve
