That’s a different compiler, @RIL: Rhinoscriptsyntax and RhinoScript
Hi, Giulio. Happy New Year. Thanks for your toturial, that’s very helpful.
But there is a error that troubles me a lot and I can’t figure out why. Here is the code:
from ghpythonlib.componentbase import executingcomponent as component
import Grasshopper, GhPython
import System
import Rhino
import scriptcontext as sc
class MyComponent(component):
def RunScript(self, crv_id):
sc.doc = Rhino.RhinoDoc.ActiveDoc
crv_o = sc.doc.Objects.Find(crv_id)
a = crv_o.Attributes.Name
sc.doc = ghdoc
return a
Compiling this code follow your tutorial, I got a new GH component without any error. But when I put this component into canvas and loaded input it get red and says:
Solution exception: global name “ghdoc” is not defined.
Do you know why? Can’t run correctly after compiling into GH component. But this code runs OK before the final step.
I have change “ghdoc” into GhPython.DocReplacement.GrasshopperDocument() and solved this problem. I hope I’m not disturbing you.
Hi,Giulio Piacentino.
Is user have to install IronPython to load ghpy files as GH plug-in into Rhino?
And can Rhino5 support ghpy files?
Hi Giulio!
Following your tutorial 1. Compiling a single component in an assembly with the wizard
I have a Runtime error
and the compile did not work
could you tell me how to fix it? why the name ‘component’ is not defined, is not defined already in line 18 ?
classs MyComponent(component):
Thanks in advance!
Hi @piac,
I use this code below often to dynamically add/remove inputs. Is there a way to translate this functionality within the compiled component?
# automnatically set the right input names and types (when using + icon)
numInputs = ghenv.Component.Params.Input.Count
accessList = ghenv.Component.Params.Input[0].Access.list
accessItem = ghenv.Component.Params.Input[0].Access.item
typeFloat = GhPython.Component.NewFloatHint()
typeBool = gh.Parameters.Hints.GH_BooleanHint_CS()
for input in range(numInputs):
access = accessList
typeHint = typeString
if input == 0: inputName = 'width'; access = accessItem; typeHint = typeFloat
elif input == 1: inputName = 'thickness'; access = accessItem; typeHint = typeFloat
elif input == 2: inputName = 'spacing'; access = accessItem; typeHint = typeFloat
elif input == 3: inputName = 'rotation'; access = accessItem; typeHint = typeFloat
elif input == 4: inputName = 'offsetFromWall'; access = accessItem; typeHint = typeFloat
elif input == 5: inputName = 'verticalOrientation' ; access = accessItem; typeHint = typeBool
else: continue
ghenv.Component.Params.Input[input].NickName = inputName
ghenv.Component.Params.Input[input].Name = inputName
ghenv.Component.Params.Input[input].Access = access
ghenv.Component.Params.Input[input].TypeHint = typeHint
ghenv.Component.Attributes.Owner.OnPingDocument()
Hi @sgaray
if you are doing this from an event handler, then it should be fine. Never do this within a solution.
Just keep in mind that you’ll need to use standard Grasshopper input parameters, not Hint-based scripting parameters. Compile a sample component with the Hints that you need, then choose to copy the code. It will show exactly what types are expected.
Giulio
Giulio Piacentino
giulio@mcneel.com
They cannot, sorry.
If you compile often or more than a single component, you must compile all components on your own using clr.CompileModules(). Do not ship dozens of components in single GHPYs, because the loading time for each single GHPY is quite long (it does not take almost any longer to load 1 to 10 components in the same file).
I like this battery. How is this battery code written??
