I’m using Rhino7 on windows 10 & the Turntable, also animation does not work properly in the most of the files!
It turns frame by frame & does not turning fluently!
I’ve upgraded my Graphic Card but nothing changed! I also try it on Rhino6 & the same problem…
What could be the cause of this problem?
Is there some workaround?
Any advice would be appreciated.
Thank you
Rhino 7 SR1 2020-10-25 (Rhino 7, 7.1.20299.23101, Git hash:master @ 8d9ce31398d29589acec390d2167dc68806d5b79)
License type: Commercia, build 2020-10-25
License details: Stand-Alone
Windows 10.0 SR0.0 or greater (Physical RAM: 16Gb)
Hybrid graphics system.
Primary display: Intel® HD Graphics 530 (Intel) Memory: 1GB, Driver date: 9-5-2020 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GTX 960M (NVidia) Memory: 4GB, Driver date: 1-22-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 461.40
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-22-2021
Driver Version: 27.21.14.6140
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.1.20299.23101
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.1.20299.23101
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.1.20299.23101
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.1.20299.23101
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.1.20299.23101
Hi Anita,
Do you see the Turntable control ?
You might try to disable V Ray, Options>Plugins page and then close and restart Rhino. Any better?
Hi Fred,
I tried it but unfortunately didn’t work
After you disabled the V-Ray plug-ins, did you close and restart Rhino?
yes I did!
I did it, but not solved!
Please update to the current service release for Rhino V7.
We’re on SR3 now and there have been important changes.
Thanks
This may be file related. Does turntable work smoothly with an empty model?
I did and no new changes on my problem!
Yes it works smoothly on empty file an also on some rare files!! but on the most the files it doesn’t work properly!
If you run the command TestMaxSpeed on one of these files that do not work well with turntable, what kind of results do you get?
