Turntable axis
Hi, I haven’t been able to puzzle out how turntable sets its rotation axis.
Would it be possible to add a setting for that, or alternatively to simply use Cplane Z by default please?
Turntable uses the same rotation axis as regular view rotation. To spin around the CPlane Z axis, go to Options > View > Rotation and select Around CPlane Z axis. From the command line: -Options > View > Rotate > Rotation=AroundCplaneZaxis.
The spin is centered on the view’s rotation center (normally the camera target). Use SetZoomTarget or Zoom Target to put that where you want it before starting Turntable.
– Dale
Aha, thanks so much!
