In Layers I am trying to find a way to turn “New detail on” to no by default. is their a way to do this?
Thanks
Paul
Thanks
Paul
Hi @paul_duterque,
There isn’t a setting for that. New layers always start with “New detail on” turned on. But you can switch many layers at once:
_-Layer _NewDetailOff * _EnterAnnotation* works too.If you set your standard layers to off and save that as your template, new files will start that way. Layers you add afterward will still start as on, though, so the macro above is the easiest way to deal with those before you add a new detail.
– Dale
Ok, I will try that, thanks!
