Turning a Solid into a Solid Wireframe/ Hollow
Apologizes in advance for my lack of proper terminology; I’m still fairly new to Rhino/ CAD.
I was wondering if there’s a relatively easy way to convert a closed polysurface or series of curves into a solid (not mesh) wireframe of a shape. I enjoy playing around with complex polyhedra via RhinoPolyhedra | Food4Rhino and wanted to know if there was any way to make wireframe and/ or hollow solids out of models like this.
A web-app I play around with on occasion ( PD - Polyhedra ) has a list of solids and has Conway Polyhedral Notation in order to manipulate the shapes into various forms. The Hollow “h” notation achieves a result that is quite possibly perfect for what I’d like to do in Rhino, with the ability to change the frame thickness and inset thickness.
I know the MultiPipe command can achieve a similar result, but I’d like shapes that have sharp, well defined faces rather than an organic, bulbous shape. This tool does in fact export natively to .3dm, but it and the other formats only have mesh data, not solid geometry.
If anyone has any insights on this. I’d be very appreciative. I’m just a nerdy novice that likes playing around with cool shapes. Thank you :slight_smile:
Hi Max,
Welcome to the forum. You can use PushPull to create parallel-sided voids in the faces of a polyhedron:
You have to create a curve on the surface to indicate the border of the hole then you can use PushPull to select the region inside the curve and push it down towards the solid’s centre.
Doing this for every face is tedious, but a lot less tedious than other approaches.
In the R9 WIP you can PushPull multiple regions in one go but trying this on the polyhedron illustrated resulted in rather messed up results, so it isn’t viable yet.
HTH
Jeremy
