Is there something you do in Rhino or Grasshopper every week that feels like it should be automated? Maybe a repetitive, menial task you’d happily hand off to an AI agent, if only you could trust it to do the job exactly the way you would, every single time?
Or maybe your office is a mix of Grasshopper users and people who’ve never opened the canvas, but who still need to run the definitions the Grasshopper crowd have built.
Some of you may already have the automation definitions, sitting in a .gh file somewhere. The hard part is everything around it: finding it quickly, re-learning the spaghetti definition you wrote six months ago, or getting colleagues to use it without walking them through the canvas.
That’s why we built Murmurate.
What it does
Murmurate is a plugin for Rhino and Grasshopper that turns your existing Grasshopper definitions into MCP tools. MCP (Model Context Protocol) is the open standard AI assistants use to connect to external tools. Once your definition is published as a tool, your AI assistant can run it for you from a plain-language request, even with Grasshopper closed.
So instead of opening the definition, finding the right sliders and baking the result, you can just ask:
“Populate the selected surface with 200 people blocks.”
The assistant calls your definition with the right inputs, and the result appears in Rhino, or back in Grasshopper if you want to refine it further.
Importantly, Murmurate doesn’t generate new Grasshopper scripts. The AI isn’t improvising geometry; it’s running the logic you built and tested. It decides which tool to use and what values to pass, and your definition does the rest, the same way every time.
How it works
- Wrap your logic in a Murmurate AI tool component. The inner canvas works just like a native cluster, double click to open.
- Declare the inputs and outputs you want exposed, each with a name, type and description. This is what the assistant reads to understand how to use the tool.
- Publish it in one click. It becomes a local MCP tool, saved as a single self-contained file you can version or share.
- Ask your AI assistant to do the task. Once it’s connected to Rhino, every tool you publish appears automatically, with no restart.
No config file, terminal, API key or code. Your logic stays in Grasshopper, where you can see it and edit it. Murmurate just lets your assistant run it.
Getting started
- It’s free. Download it here.
- Requirements: Rhino 8 or 9 on Windows. (Mac support is on our list, so if you’d like to help test it, please get in touch).
- Bring your own agent. It works with Claude Desktop, Claude Code or any MCP client, and also supports local models.
- What’s in the package: a Rhino plugin that runs the MCP server, and a Grasshopper plugin with the authoring tools.
- Murmurate is in public beta, so use it for evaluation and testing rather than on live projects. Tools published with a beta version may need republishing after a later update, so keep copies of your Grasshopper definitions.
Workshop: 28 October
There is a little learning curve for the grasshopper authoring the tools, and we are working on the documentation site. But if you’d like a guided start, we’re running a one-day, live online workshop on 28 October, covering MCP basics through to wrapping and publishing your own definitions. You can find times and booking details on the workshop page.
We’d love your input
We’re keen to hear your thoughts, good and bad, and feature requests are very welcome. And if you’ve got a repetitive task you’ve been putting up with, tell us about it below. We are very much in the early access beta phase so any testing and feedback is invaluable.
Thanks,
Tom
I just wanted to end with a couple of examples (just note the videos are speed up to be under 20s long - I wish Claude was this fast!):
