Turn off shadows on certain objects
Hi Guys,
Is there a way to turn off shadows on certain obejcts in the viewer, but keep them for others.
What I want to achieve is to showcase the dimensions of the object. But I do not want those dimensions to cast a shadow. Only the object itself should cast a ground shadow.
Any suggestions are welcome!
At the moment, this setting cannot be controlled through Grasshopper and would need some work using the viewer API. Our team will discuss the best way to control cast shadows and I will let you know once we make progress.
In the meanwhile, you could use 2D Text Tags instead of 3D ones, which would not cast any shadow in the scene.
Hi Mathieu, I’m not a big fan of the 2D tags. Let me know once you implemented a solution!
