Tube laser cutting tolerance vs clearance
C# Rhinocommon Boolean functions used to create interlocking tube structure. Is using tolerances enough to insure that the structure can be assembled? Or should explicit clearances used to create gaps for easy assembly.
Hi @Rustem_Sharipov ,
Can you post a screenshot of the tube fitting you are trying to manufacture?
Thank you.
Hi Rustem -
Yes, they must.
Please see TurcYurt.com
