Working on a tsplines surface in box mode. I went to go into smooth mode and it will not do it.
I checked edit uniform and fixed a red star, all looked ok.
I noticed a red do t floating in space. I can’t select it to delete it.
I noticed that when I am in verts mode and when I move a vert I see yellow lines going out to several locations in space. One of those goes to the red dot. I can’t select verts out there though.
Has anyone seen this happen before? What do you do?
Enclosed is two jpegs showing dot and yellow lines that travel to it.
thanks
Help
I checked to see if I had any red stars or seashells in the model. Their are none. All looks clear in wireframe mode.
That red dot is outside the solid area,per the pictures that I shared. I can’t select any surfaces near it.
Any other ideas?
Usually in T-splines the red points signal vertices/polygons that are not properly welded.
So you might have double vertices that need to be manually welded to build a smoothable T-Splines mesh.
But that “ghost” mesh does seem strange.
Have You tried exporting the t-splines mesh and putting it in a new, “pristine” 3dm file?
You might also try to convert the t-splines mesh into a normal mesh. maybe then you can get rid of the “ghost” mesh, then reconvert to T-splines and You should be good to go.
i am also having the red dot problem and also the t-spline mesh wont let me contruct an edge in the areas next to the red dots. Append face wont also work to reconstruct the mesh. Serious help needed please.
