Hello everybody! This is first time when i dont know how to solve properly surface. I somebody will be so kind and would take a look on this.
This is highway junction - i try to model ground from dwg reference. and then i will need to cover this with road whole project is for rendering purposes only but i’d like to use edge softening for this slopes so i need to be quie accurate here in terms of tolerance.
I tried already all kind of blending patching etc.
Hi Pascal thanks for response. Yes i tried that approach but if you join them together edge softening will fail on patches btw. big green one won’t join at all (below tolearnce). Do you think that spliting edges and making srf blends with curvature will do the job ? I mean instead of edge softening.
Hi Przemyslaw - it is dirty-work but for a rendering you might get away with forcing edges to join - I remade the patches with 40 spans and stiffness at .5, then Joined. The unjoined edge I forced with JoinEdge - please see help about this command - use with caution - I’d say it is OK for a rendering…
Then EdgeSoftening at 25 or 50 … now, the object does not look softened in the area of the patch edges, as you pointed out, but I see that making the mesh settings a little finer in DocumentProperties > Mesh cleans that up - set a custom mesh setting >Detailed controls > Max distance edge to surface of .25 and 256 minimum initial quads.
I found that normals was fliped also - i’ll try force joining and refining mesh - i used to do this by custom mesh for that object instead of refining all in viewport while working
Anyway thanks for trying to help in this case. I would like also to ask if it is proper way of making this kind of thing in Rhino or for sth like this there is better aproach ?
Hi Przemyslaw - I guess structurally this is like the perennial Y-branch problem - what do you do when the structure branches and surfaces are limited to the rectangular topology… - it is certainly possible to make much cleaner primary surfaces and to make ‘proper’ transitions, but it is a bit of work and I’m not sure if that is worth it in the context of making a rendering-
Yeah… to make that layout work you’d want the whole thing to be made from simple clean surfaces so that it all joins up nicely - as I say, probably impractical in this context.
I know that i should start new topic in gallery but don’t have time so i’ll just update it here. Project was done entirely in Rhino, rendered with Thea some minor post in PS.
