I think logging in with McNeel account currently doesn’t work. I have tried without VPN as well.
I just tested this, and it worked for me. It might have been a temporary problem. Could you try again?
Still doesn’t work, tried 10 sec ago.
This is how it looks for me:
Many thanks for sharing the screen recording! I tried using different browsers but could not reproduce it yet.
Which browser are you using?
Does an error show up on the browser console?
As a temporary workaround for you, shall we change your account to a password-based login?
Just figured out the root cause: Your account got suspended because the subscription of the organisation it is linked to got cancelled. The platform doesn’t display the message and instead shows “Not implemented yet”, which is obviously a bug that will get fixed.
Ha ha, ok. Wonder if they even know that they cancelled the subscription. I’ll chase that up, thanks for letting me know.
We did send several reminders…
I don’t doubt you, I will have this sorted. Thanks again!
It still should log me in though, even if I don’t have a valid subscription?
FYI, subscription is now getting sorted, got stuck at accounts dep.
The issue is this: The user you are trying to log in with is member of an organization account, and got suspended because the subscription got cancelled. Apparently displaying the corresponding feedback message doesn’t work in case of SSO login.
Shouldn’t it just revert me back to the free version of subscription is cancelled?
I am sorry this case isn’t properly documented, we will improve this. What happens is this:
