Hi guys,
does anyone know how to fill the gaps in the object attached? I’m trying to create an approximation of a biosphere type shape, basically will want to show clear material in those openings.
Hi guys,
Hi @hvolykhine , Maybe if you attach the 3DM file, someone will be able to help further…
https://drive.google.com/open?id=1vrgSf2RYfwBedBNtNv9n13CccGXyCfDE
File attached^ Anyone?
Hello - if you make some sections (Section command) through the object you’ll see there are many self-intersections:
Hi Pascall, I think those were left from when the model was initially generated with grasshopper… now basically what I am trying to do it fill in the physical empty spaces in the shape, almost as though blowing up a balloon inside a frame which I have made…in order to fill in the large gaps in the skeleton
