i am trying to find objects in a layer with “Light” in the name i then need to create points at the center of the objects(boxes) and create coresponding boxes 2x4x2 exactly 2 units below the center point found on the objects in the layer i need to make those objects on a specific layer named “Flicker Evaluation”
anything helps!!!
thanks
import Rhino
import scriptcontext as sc
search_string = "Light"
for layer in sc.doc.Layers:
if search_string.lower() in layer.Name.lower():
for rh_obj in sc.doc.Objects.FindByLayer(layer):
if rs.IsSurface(rh_obj.Id):
rc = rs.SurfaceAreaCentroid(rh_obj.Id)
