Hi all i need to cut this solid (the red “outer” layer) in half by a plane defined by the curve (defined in the Cyan “Fuselage” layer), however, I can’t get them to fully intersect at the wingtips!
I’d draw that as a simple 2d curve in that view and extrude the curve, using the extrusion as the splitter.
I noticed the edges first by just seeing them. The What command confirmed that edges are way out of tolerance.
