Uploading: image.png(1)… I want space truss structure to fill the space between these 2 surfaces
but I get strange results
How to fix it
Truss structure issue.3dm (886.9 KB)
How to fix it
It seems your referenced surfaces have quite distorted UV topologies and don’t match each other.
Check this attached example and you’ll know what I mean.
Bad input causes bad output, should I say…
Thanks for you reply and your time, I’m still learning
but why UV distortion happened? does this because it was SubD Geometry
