Trunk width
Is there a way to increase/decrease the trunk/branches width? The current thickness start and end parameters seems to affect the length as well, instead of affecting the width only.
The only way to currently change the width independently of the length is to go to the Joints dialog box and change each value. Very cumbersome. How would you like to see this implemented? I can probably change the Elongation param to Length and have them operate independently. Would that be easier?
Yes, I think so. Increasing the thickness should not result in larger branches. Currently it looks like the branch length is proportional to both the elongation value and the start/end thickness. I would find more intuitive if length was independent of thickness.
OK-- will do. I should have an update out today or tomorrow.
Added a new stable build-- should update automatically.
