Hi all, does anyone found a solution to get a boolean pattern aftern an intersection operation in grasshopper? What I am looking at is an intersection between Brep/Plane.
Thanks in advance!
https://grasshopperdocs.com/components/grasshopperintersect/brepPlane.html
Are you looking for this component.
Cheers,
BVR
Yes is this component but as a output I would like to have a true/false pattern
Thanks, I didn’t know that connecting it to a boolean component I would be able to get the pattern. Thanks!
You are welcome. You dont even need Boolean if you want to use pattern as an input for other components. 0 is recognized as False, any positive integer as True.
