Troubleshooting bend constraints/non-continuity
I’m running into an issue when using the Bend function - my bends are not maintaining parallel edges and they’re going all wacky. For example, I’m simulating a bend in sheet metal and seeking a crisp bend in the material. I’ve been following tutorials on YouTube, but not getting the same results. I have a feeling there is a constraint I need to add or toggle on/off but I can’t seem to figure this one out. Any suggestions?
in case of sheet metal.
flow / flowalongsrf would be the correct choice.
bend has little thing to do with actual manufacture problem
