What is the best way to synchronize render settings between two Rhino instances? I tried Tools | Export Options from Rhino Instance 1, then Tools | Import Options on Rhino Instance 2 but it seems like the Render settings are not included.
Render settings are mainly document settings. You could save a template file with the settings as you’d like and start new files from that template in different Rhino instances.
It appears that Rhino render settings (backdrop, dpi, gamma, lighting, etc. ) are set on a per 3dm basis. I’d like all of the render settings in all of my 3dm’s to be consistent.
For new 3dm’s, I am starting with a template that has everything set to my current rendering configuration. That doesn’t solve the hundreds of existing 3dm’s that have previous or even default rendering settings. So I’m looking for a way to synchronize them somehow to the current settings.
Hi Pat - honestly, I do not know if that is possible - I’ll look to see if it seems possible to script, but I do not know if what we’d need is available in RhinoCommon… it may very well not be.
