Hello everyone,
I have started working earnestly with R8. I’m currently working on an STL file that I will mill out on my CNC router. My issue is in selecting end points in order to move the model to origin.
I opened the STL in R8, drew a bounding box to get the size, which was several hundred inches long. I scaled it to 1/24 scale which gave me a 16" long x 10" wide by 2.5" high model. My next task was to move the model from it’s original position from outer space to 0,0,0.
Here’s where the trouble started…
I tried to select an endpoint from the bounding box in order to move the model to origin before resaving aa an STL and exporting to the router control package. I had this problem way back on R5 or R6. I do not remember the remedy that I used back then.
I’m sure that this is operator error rather than changes in R8. If someone has a solution or commands to do this in R8, I’m all ears.
Best,
Terry Wellman
