Hi
I’m having trouble with a offset surface. Two of the vectors are pointing in the wrong directions, giving me a weird result.
Can I control the direction of the vectors somehow, or is there another solution?
BR Kim
Hi
BR Kim
Attach File?
Have you tried Flip? It might allow you to change the two directional vectors.
Unfortunately it gives the same solution
I’m guessing it has something to do with the way I made the surface, somehow.
I used the control points to make the edge of the surface, but maybe there is a better way?
Hi @kvi
Yeah, you would probably be better off with a trimmed surface in this case, instead of having the control points on the edge tangent to each other.
-Jakob
That did the trick, tanks!
