I have a configurator in ShapeDiver, Mandala Test - Join all Curves - ANY HELP - ShapeDiver, that creates a mandala like shape. I need to create a file to be cut on Laser or CNC Router where all the curves are joined together.
Similar but not exactly. I wanted to be clear about what my goal was, thus the new thread. The old thread stated that I needed to join the curves so that I could extrude the curves. Though that was accomplished, what I really needed was to have a shape that is continuous, without breaks.
The DXF export is currently limited to polylines and meshes but we are working on ShapeDiver plugin upgrade which will come with better export options.
For now, convert breps to meshes for the DXF export. In case paths for laser cutting are required, you can export polylines in a separate export component.
Also, to speed up your model we recommend adding a toggle for exports, read more below:
