Trouble hosting elements
Hi there,
I’m using grasshopper to generate some void elements that I would like to host onto faces of beams that exist in my Revit document. I’m having trouble utilizing the hosting nodes, which seem to only recognize a limited category of things as eligible hosts: slabs, toposolids, etc. but not beams.
I wondered if I could bypass that and set the host manually through setting the parameter, but that appears to not be accessible through the element parameter node.
Please help! I’d like to be able to put holes in my beams!
Please check the following post
You need to manually perform the Boolean cut or else use the Revit api the cut the beam with void elements.
