Trouble creating a chain operation
Hi, I made a script to build a tent-like structure. I would like to make different iterations (height, width,etc) that are assembled in a chain. For now I have a first version of my script with a newer version attached to it, but I’m having trouble adding a third part as everything is link to the first when I copy paste the script… it gets messy. how could I replicate the script easily so part 3 is attached to 2, 4 to 3, etc?
Capture
I hope it makes sense, thank you so much!
Florence
Structure.3dm (51.0 KB)
Structure2.gh (97.7 KB)
Structure Edited V0gh.gh (105.1 KB)
I try to simplify your script.
Wow thank you so much!!! Better than my spaghetti :joy: By any chance, would you know how to bring back the sections with different start and end height (see picture)?
The graph mapper component you introduced is good to make slight variations that make the structure look realistic. See example below, I would need to raise/lower/widen the building at given sections. I don’t know if it would be possible to control different sections of the same curve with 1 script or if it’s better to use 1 script per building section (in this case I would have to adjust the connection dimensions manually so it creates a continuous bldg).
Also see updated script, I chose to sweep1 the elements separately to control diameter.
Structure3.gh (27.5 KB)
Thank you so much for your help!
Structure Edited V1.gh (103.5 KB)
looks so cool! Thanks :slight_smile:
