Trimming these surfaces on each other chokes Rhino 7
Here it takes several minutes to trim these surfaces in Rhino 7 SR11 then again several minutes after confirming the trims. In Rhino 6SR35 it goes almost instantly.
trimming_chokes_rhino_7SR11.3dm (928.5 KB)
I can confirm the regression:
https://mcneel.myjetbrains.com/youtrack/issue/RH-66222
Thanks
I just got notification I can test the fix in a day or two.
Thanks,
I just sent in a tech report linking to this thread that shows I think related behavior.
I hope to test it tomorrow or Thursday.
It’s slated for 7.12
@Gijs
The new 7.12 build has the fix in it.
Your example trims quickly now.
Any luck?
only some :slight_smile:
the trimming indeed goes faster now with the example posted here, however the boolean difference example I sent to tech support still is slow. I could not get that to trim fast either, same for intersect and split. However if I first ShrinkTrimmedSrf on those Breps, it works fast as in Rhino 6
It seems related but maybe not.
I’ve added a new bug report:
https://mcneel.myjetbrains.com/youtrack/issue/RH-66281
Thanks
