Trimming the joint between two curved 3 mm sheets — Split and BooleanDifference fail
Hi everyone,
I’m preparing a sculpture to be fabricated from 3 mm stainless steel sheets, which will be cut, formed and welded together.
I know how to add thickness using OffsetSrf. My problem is adjusting the joints between sheets with complex surfaces so they fit together without overlapping before welding, while preserving the exterior shape.
I’ve started with two sheets. After adding thickness, What confirms that both are valid closed solid polysurfaces. However, Split and BooleanDifference do not produce a correct result. Intersect generates an open polycurve with 13 segments that revisits some points. In one attempt, the main piece was left open and small fragments appeared.
I’m attaching SS.3dm with the current state and a video showing the two sheets.
Could someone inspect this joint and show me how to correct it? I need a workflow I can repeat on the other pieces. I’m a Rhino beginner, so I would appreciate step-by-step instructions specifying which object or face to select for each command.
My question concerns trimming and fitting the edges while accounting for thickness, rather than unfolding or the K-factor at this stage.
Thank you.
PLEAHSE HELPÇ.3dm (13.1 MB)
