V4
I have given my file a good trim, remove unwanted items, deleted dimensions, etc. Still it is as slow as before.
Does it remember what used to be there ?
How do I cleanse or purge memory of this file ?
I have a lot to add yet with it this slow already I fear for the future.
Would exporting it out to a new file solve things ?
Are there ways of speeding things up.
TurboCad chap said dont draw many rivet holes, draw one as a block then create block instances. Standard practice in CAD he said else the program sees every hole as a separate item.
Thats a new one on me, is this applicable to Rhino ?
I did find when adding rivet holes things slowed down.
I create one solid cylinder then copy it to the rest of the locations I need to ‘drill’ out holes in my solid, then do a boolean and create the holes.
He showed me a block instance (if that was what it was called) of a circle in 2D view, does this apply though to 3d view ?
How would I use this method to create my cylinders and position them before punching holes with them into my solids ?
I have a large jpg plan in the scene, I often have a few more. Black/white and smallest file size I can manage.
Its turned off.
Does Rhino run things speed wise as if all layers are turned on ?
Steve
