Hi everyone, I can’t cut/split vertical elements (cladding and interior structure) using box so I can have a portal in the building facade. If the 'output was brep or curves I would know how to do it but with geometry I don’t. Does anyone know how to do it? Thanks
National Pavilion of Biodiversity_portal.gh (59.5 KB)
Is this the expected result?
Oh yes! How did you manage it?
Thank you, but the problem persists, at least in part in that I can only cut the covering and not the inner structure.
Try subtracting from the geometry output of the move component instead
All breps are closed. What does not work on your end?
National Pavilion of Biodiversity_portal.gh (48.2 KB)
