I would like to make a large opening, which is bigger than 1 surface element (brep). I noticed it does not remove the brep which is fully boxed (trim solid command). It only removes the parts of the adjacent bpreps which are not fully boxed.
Does anyone have a suggestion how to remove also the elements which are fully boxed?
a solution would be to unify the surfaces (breps) into 1 large surface. However I would like to keep the individual surfaces, so this isn’t an option…
thank you in advance!
- surfaces
- volume to trim with
- result: first surface not trimmed/removed (because it was fully inside of the box).Trim surface with larger 3d solid.gh (16.6 KB)
