Trim offset curves to give new closed curve
I want to offset curves by varying distances, then trim them all to give a new closed curve.
Please see attached.
Thanks,
Dan
Are all your curves made up of linear segments?
This could be a way.
David,
Yes, the curves will be linear segments.
In the opposite case, where the segments were offset to the outside, how would you connect these curves? Fillet?
Thanks,
Dan
HS_Kim,
Thanks for your solution. I can see this would work, but am surprised at how involved it is!
Dan
