changing to extend line = no was what made it start working?
I can repeat that here. thanks for the info I’ll write it up-
If I place another object in the scene at the same level, the trim fails on it too.
If I place an object in the scene at a lower level, the line trim works on it and then works on Peter’s object.
Also, I found that if I snap to the edge of the object, the trim line works - it only fails if it crosses.
I think that is because the cutting line may have to be on top of the object. I placed a couple of points at a higher level than the surface so I could draw the line higher by snapping, rather than on the cplane, and the trim worked:
Note that from previous results it seems likely that the “on top” constraint only applies to the first object to be trimmed.
Hope that helps track the issue down, @theoutside .
Regards
Jeremy
This bug is fixed in the version 8 WIP.
Hi Greg,
I’m still seeing this bug. It happens in the front view in the attached file, for example. I’ll make a video if it helps.
trim with line still not working 001.3dm (71.7 KB)
hey Peter, are you testing this in the v8 wip? the fix is only 8.x and newer.
Nope, in v7.
